Nvidia (Zotac) GeForce GTX 285 1GB
Written by Tim Smalley
January 16, 2009 | 10:41
Tags: #1gb #285 #card #consumption #evaluation #geforce #gtx #heat #performance #power #review #thermal
Companies: #nvidia #test
Crysis
Publisher: Electronic Arts
Crysis is seen by many as the poster boy for DirectX 10 and it will make your system cry, quite literally – it’s a monster! It doesn’t come as much of a surprise then, that the graphics are something special – they’re above and beyond anything we’ve ever seen in a PC game.
We tested the game using the 64-bit executable under both DirectX 9.0 and DirectX 10 with the 1.21 patch applied. We used a custom timedemo recorded from the Laws of Nature level which is more representative of gameplay than the built-in benchmark that renders things much faster than you're going to experience in game. We found that around 27-33 fps in our custom timedemo was sufficient enough to obtain a playable frame rate through the game. It's a little different to other games in that the low frame rates still appear to be quite smooth.
In addition to testing under both DirectX 9.0 and DirectX 10 with all quality details set to High, we feel it's about time hardware should be able to handle the game with the in-game settings tuned to Very High. The game has been out for at least a year now, so it's time for hardware manufacturers to catch up with the software.
We forced 8x anisotropic filtering in the driver menu as there is currently no support for it in game and tested at 1,280 x 1,024, using 0x, 2x and 4x anti-aliasing, 1,680 x 1,050 using 0x and 4x anti-aliasing, 1,920 x 1,200 using 0x and 2xAA and 2,560 x 1,600 with 0xAA. By extensively testing using anti-aliasing in very high resolutions in conjunction with Very High quality in-game settings, we'll be pushing even the bleeding edge hardware on test to the limit.
Crysis
1,280 x 1,024 0xAA 16xAF, DirectX 10, Very High Quality
  • Nvidia GeForce GTX 280 1GB SLI
  • Nvidia GeForce GTX 295 1,792MB
  • Nvidia GeForce GTX 260-216 896MB SLI
  • ATI Radeon HD 4870 1GB CrossFire
  • ATI Radeon HD 4870 X2 2GB
  • Zotac GeForce GTX 285 1GB AMP!
  • Nvidia GeForce GTX 285 1GB
  • ATI Radeon HD 4870 512MB
    • 66.9
    • 40.0
    • 61.4
    • 38.0
    • 58.4
    • 35.0
    • 47.9
    • 26.0
    • 45.8
    • 26.0
    • 40.8
    • 24.0
    • 39.9
    • 23.0
    • 35.9
    • 21.0
    • 31.6
    • 18.0
    • 27.3
    • 14.0
    • 27.3
    • 15.0
20
30
40
50
60
70
Frames Per Second
  • Average
  • Minimum
Crysis
1,280 x 1,024 4xAA 16xAF, DirectX 10, Very High Quality
    • 58.4
    • 36.0
    • 52.6
    • 33.0
    • 50.6
    • 31.0
    • 41.9
    • 22.0
    • 40.0
    • 22.0
    • 36.0
    • 21.0
    • 34.6
    • 20.0
    • 31.4
    • 18.0
    • 27.1
    • 16.0
    • 23.1
    • 12.0
    • 23.1
    • 11.0
20
30
40
50
60
Frames Per Second
  • Average
  • Minimum
Crysis
1,680 x 1,050 0xAA 16xAF, DirectX 10, Very High Quality
    • 54.7
    • 33.0
    • 49.9
    • 31.0
    • 47.7
    • 29.0
    • 39.1
    • 22.0
    • 37.4
    • 22.0
    • 33.3
    • 20.0
    • 31.9
    • 19.0
    • 29.1
    • 17.0
    • 25.3
    • 15.0
    • 21.7
    • 12.0
    • 21.6
    • 11.0
20
30
40
50
60
Frames Per Second
  • Average
  • Minimum
Crysis
1,680 x 1,050 4xAA 16xAF, DirectX 10, Very High Quality
    • 47.5
    • 30.0
    • 42.0
    • 27.0
    • 40.7
    • 25.0
    • 34.0
    • 19.0
    • 32.5
    • 19.0
    • 28.9
    • 18.0
    • 27.7
    • 17.0
    • 25.3
    • 15.0
    • 21.6
    • 13.0
    • 18.2
    • 9.0
    • 18.1
    • 10.0
20
30
40
50
Frames Per Second
  • Average
  • Minimum
Crysis
1,920 x 1,200 0xAA 16xAF, DirectX 10, Very High Quality
    • 44.2
    • 27.0
    • 40.5
    • 24.0
    • 38.5
    • 23.0
    • 35.4
    • 21.0
    • 34.1
    • 19.0
    • 27.0
    • 15.0
    • 25.8
    • 15.0
    • 23.5
    • 13.0
    • 20.2
    • 11.0
    • 19.5
    • 10.0
    • 19.5
    • 10.0
20
30
40
Frames Per Second
  • Average
  • Minimum
Crysis
1,920 x 1,200 2xAA 16xAF, DirectX 10, Very High Quality
    • 39.4
    • 24.0
    • 34.6
    • 22.0
    • 33.6
    • 21.0
    • 32.4
    • 19.0
    • 31.2
    • 18.0
    • 24.0
    • 14.0
    • 22.9
    • 13.0
    • 20.8
    • 12.0
    • 17.8
    • 10.0
    • 17.6
    • 9.0
    • 17.5
    • 9.0
20
30
40
Frames Per Second
  • Average
  • Minimum
Crysis
2,560 x 1,600 0xAA 16xAF, DirectX 10, Very High Quality
    • 26.6
    • 14.0
    • 22.9
    • 9.0
    • 21.8
    • 8.0
    • 21.6
    • 11.0
    • 20.9
    • 10.0
    • 16.0
    • 9.0
    • 15.2
    • 8.0
    • 13.8
    • 7.0
    • 11.6
    • 7.0
    • 11.5
    • 5.0
    • 11.4
    • 5.0
10
15
20
25
30
Frames Per Second
  • Average
  • Minimum
The additional performance available with the GeForce GTX 285 means that Crysis is now playable at 1,680 x 1,050 0xAA with very high in game settings. It pushes the average frame rates above the 30 frames per second mark for the first time with a single GPU graphics card and maintains a minimum that is respectable at 19 fps. The Zotac GeForce GTX 285 AMP! Edition is a further four percent faster and the minimum is another one frame per second higher - not a massive difference, but it should a be slightly smoother gameplay experience.
null
